Here is one picture-the rest qre too dark-it is night time here, and I guess the flash just just isn't cutting it.
There is a left and a right, but the only dfference I could see is where the hole for the grease fitting is, they are mirrored in placement left to right. I do know Carl is right, they are threaded opposite.
I will be happy to take more pictures tomorrow if they will hlep.
Will
And if you don't buy OEM parts, you *may* find that the parts you receive do not have any provision for grease fittings at all, also no "castellated nuts and cotter pins" (self-locknuts provided instead) Distributor called them "Sealed" and "Lifetime Lubricated". :stupid:
I was shocked when that is what I received.
RE: outer tie rod ends.
I am having a hell of a time getting them off.
The idea is to turn the lock nut toward the centre of the rack and the tie rod end away from the rack correct?
I have no idea how you guys get the leverage to do this. :sleepy:
Pointers would be excellent.
Remeber the thread is opposit on each end-easy to forget-tightening instead of loosening.
2 big wrenches, or 1 big wrench and a vice. Examine the parts, the end and its mate have flats on them for wrenches or a vice.
Just in case you just need a gobfull, Quit chucking a sickie and give it a burl you mug:laugh: !
Penetrating oil never hurts, and in the last resort, a heatwrench on the nuts will pretty much makeany thing(or anyone LOL ) let go of anything!
Will
You remember that the threads are different on each side, right? Look the threads over carefully to see which direction to attack with a wrench.
If you have separated the outer tie rod from the steering arms, re-attach them "loosely" to keep the outer T/R from turning as you loosen the jam (lock) nut. It's been a couple years since i did this so I don't rememeber the exact details, but I don't recall needing to do anything but the above to loosen the jamb nut. Sprayed a bit of lubricant at the threads of the Inner T/R where they go into the outer T/R just to make the unthreading a bit easier.
If the steering rack is already out of the car, chuck the outer T/R in a vice to hold it, then go after the jamb nut.
EDIT: Will, Stop snorting those diapers and Go to Sleep for chrissakes!
I am coughing my brains out! No diaper duty for a while. I have been sick(medically treatable any way) for 5 weeks-in and out of Pneumonia, but consistantly Acute Bronchitus. The Dr. has finally put me on a script that is starting to turn the tide. I have been a healthy person until this year, next time, I will not wait to "let it pass", it only made it worse. Hopefully the tide is turning, and I can get back to living and being active again. Even sick I got my nuts off(you guys should be ashamed-I ment the jam nuts that are pertinant in this thread)! Perverts!!!
Will
PS-no chrome plating ot polishing on my suspension, I used tiewraps instead of steel rings for the bellows-I thought it would be better to make parts that will get dirty less noticeable, than to highlight the dirt on them!
  • Who's Online   1 Member, 0 Anonymous, 1,485 Guests (See full list)
