Site Updates this Weekend ×
Interior rivet alternatives?
  • 1 month later...
I ended up using s 1/8 inch wood dowel for the pins. I checked it first by pushing the dowel though an old rivet, and needed to sand it just a touch, but it fit perfectly! just cut some to length- about 15mm. Push them in and paint with a cotton swab. You should get a few dozen pins from a 36" dowel.
I thought I found a good source of rivets on ebay, Florida Auto Fasteners--20rivets for $8.99. They arrived today and I found out why they were (relatively) cheap. Besides a dull and very rough finish to the rivet head, the center pin is actually molded onto the head of the rivet! What a unique way to prevent the pin from being lost.
That pin is barely held to the head by a skin thin bond. It is broken off and then pushed into the rivet head. It is a viable means of producing the rivet and pin in one step. I suspect that Nissan rivet are produced this way and then separated for packing.
I got a call from them this morning. Apparently you're supposed to put the rivet into the panel hole and hit the pin with a hammer to release it from the head. Not quite what I want to do to 29 year old plastic panels. But even if that worked the finish on the head is pretty bad, dull and very uneven. You get what you pay for.
That said, the seller definitely wanted to keep me happy. There were no problems getting a refund.
  • 2 years later...
