Door dropping/ lock woes - Body & Paint - Classic Z Car Club Skip to content
G'day,
As of late I've been having trouble locking the drivers door on my Zed with the key, it locks, but only by pushing down the plungery thing ( you know what I mean :stupid: )
Today I looked at the Zed side on and noticed that the door appears to have 'dropped' a few mm. I was thinking this could cause the problem, as the key turns the barrel inside the door fine ( I've had it all apart to see), but when you turn it the plunger/knob bit doesn't seem to be lowered far enough to lock. The door has a bit of movement in the hinges, so I was thinking this is the problem?
If it is, how would I go about 'lifting' the door, or would I need hinges?
Any help appreciated. :ermm:
