Thanks 26th, I am going to start tonight. I think I will do it by hand like you suggested and start with a 180 and work my way up to a 400. You are right, the body man told me the sanding was just to smooth the car up. So you suggest applying a vacuum cleaner brush directly about the body and vacuum the dust off? I was thinking about pulling it outside for a sec and blowing it off with an air compressor. Maybe I will try a combo of the 2. Thanks for all the help.
Hey AWC, it went really good actually. I started off with a 150 in my garage and my girl friend actually helped out! Anyways I went over the car in sections, fenders, hood, roof, etc. I eventually worked up to a 300 grit and the body was super smooth. I actually found a local hardware store that sold OSPHO so I bought some there and applied it. For spraying the primer, I used some poles and fabbed up a "spray booth" in my garage with a tarp and some rolls of clear plasitc. I got my uncle to come over and spray the primer because he has messed with cars a little bit, but all and all it went pretty well and I supposed I saved myself atleast a couple hundred bucks.
  • Who's Online   1 Member, 0 Anonymous, 1,472 Guests (See full list)
