i've located someone who wants to sell parts from a 70/240z vin#403, manufacture tag 403 nov 69.he has six boxes of stuff, mostly small parts for $200.($160 U S ) i wrote down the list over the phone hastily.(might of missed some parts) what i want to know is, are these parts more unique because they're from a low vin # or not. maybe 26th-Z can answer this question, also is there such thing as hatch glass without defrost wires?
p.s. the car was a rust bucket,hence he keep parts.
https://www.classiczcars.com/topic/14844-vin403/
here is some of the stuff he's got
rad
4 hub caps( D or Z caps- don't know)
chrome window frame(both)
rear windowframe(hatch)
hatch glass (no defrost)
hood vents (the ones over the battery)
starter motor-alternator
pair arm rest
pair seat sliders
door mirror
running lites(3 of 4 in great shape)
center console
rear brake drums
pass door glass
2 window mechanisms(wind ups)
duct work
seat belt stuff(rough shape)
pair wiper arms & blades
20-160 speedometer
tach(7-8 rpm)
feul amp & guage
temp& oil guage
clutch and brake master cylinder
trunk lock & key
universal joint
orange breather
floor mats
also got the manufature tag and vin# tag
sounds like it's worth $200 what da think
https://www.classiczcars.com/topic/14844-vin403/#findComment-110990
ZHead,
Kats' site has some interesting pictures and information about the earliest 240Z:
http://www.geocities.jp/datsunz903/
Early 70 Z's had vented rotors? really? never heard about that before.
Bambi,
Here's what Kats has on his website for what I believe they are referring to as slotted rotors:
http://www.geocities.jp/datsunz903/frontdisc.html
https://www.classiczcars.com/topic/14844-vin403/#findComment-111001
Yes, I think it's worth $200.
I know a fellow in Tampa looking for clear hatch glass. Of course, the 'D' hubcaps are valuable - IMO $75+ each. Let's see...I would like the hood vents. The 40 amp alternator is early. I have yet to see much difference in the starter motor. Peculiar interior parts would include the seat belts, console / ashtray, seat belt hooks, seat cushion guards, "red dot" center mirror, and perhaps the floor mats.
https://www.classiczcars.com/topic/14844-vin403/#findComment-111011
I screwed up that post.
Yea, it's worth $200 and if you would like to pass the whole lot over to me, let's talk.
Here's what is peculiar to the early, early cars:
rad
****4 hub caps( D or Z caps- don't know)
****hatch glass (no defrost)
****hood vents (the ones over the battery)
****starter motor-alternator ( 40 amp alternator )
pair arm rest
pair seat sliders
door mirror
****center console ( varies - choke plate, ash tray )
rear brake drums
pass door glass
duct work
****seat belt stuff(rough shape) ( early buckle )
****20-160 speedometer ( pretty much all the guages per series one )
****tach(7-8 rpm)
****feul amp & guage
****temp& oil guage
****trunk lock & key
universal joint
****orange breather ( without the flapper )
****floor mats ( perhaps rubber mats )
All of this is fairly peculiar to early series one cars. I don't need the console and depending on how nice it is, they can bring $300 alone. I don't need the 'D' caps either. I am interested in all the rest.
Here are a couple of shots of early inspection lids. Notice how the hood tab / seat for the hood cushion is riveted on. They have a slot on the back for the plastic clip. Also - early hood bumper.
https://www.classiczcars.com/topic/14844-vin403/#findComment-111013
Here is the "vented rotor" Dave is talking about. I call it a "vented hat" rotor. The hub is slotted. Remember, the backing plate for this brake is ducted?
Thanks for the pic, Chris. Yeah, I'd call it a vented hat rotor also. Otherwise, much confusion could result since it's not a true "vented rotor" in the common sense of the term.
IMO, it makes sense that Nissan went away from that design. It doesn't appear to be very beefy.
https://www.classiczcars.com/topic/14844-vin403/#findComment-111032
How about the engine bay fresh air vents. The earliest ones have a metal flange holding them in, while after that, they went to a metal tab.
http://zhome.com/Classic/Restore/FreshAirIntake.htm
I still have one of the early ones from #215, but I'm still looking for the drivers side...
And if the car has the "ducted" front disc backing plates, I need the passenger side one of those too...
https://www.classiczcars.com/topic/14844-vin403/#findComment-111035
  • Who's Online   1 Member, 0 Anonymous, 730 Guests (See full list)
