crap.. l28 clutch in l24 tranny, didn't work.
I was told that so long as I kept my 240z pressure plate and flywheel, that the 280zx clutch disc would bolt up fine. I was told wrong. The car won't go into gear when running.
2 questions,
1) what do I need to fix it? Just a 280 collar? Is that all?
2) I think I can get a good deal on a 280z 5-speed tranny locally. If so, will just swapping in the 280 tranny suffice? That would mean I'd have a 280 collar, 280zx clutch, 240z pressure plate, 240z flywheel. :stupid:
  • 3 months later...
Centerforce I clutch set is designed to use the stock components. Just make sure you have the Centerforce set spec'd for a 240Z and not a 280Z.
If you are using a Centerforce II clutch set you have to use a 280Z T/O collar to make it work in a 240/260Z
