will_sphyrna Posted February 17, 2005 Share #1 Posted February 17, 2005 i need to know where the fuel pump relays are located. thanks Link to comment https://www.classiczcars.com/topic/15021-fuel-pump-relays/ Share on other sites More sharing options...
will_sphyrna Posted March 7, 2005 Author Share #2 Posted March 7, 2005 anyone know where they are? Link to comment https://www.classiczcars.com/topic/15021-fuel-pump-relays/#findComment-115491 Share on other sites More sharing options...
Bambikiller240 Posted March 7, 2005 Share #3 Posted March 7, 2005 What year and model? (that always helps) If you are refering to a 73 240Z. I *believe* that the answer is: There is only one and it is on the passengerside kick panel with the other relays. Link to comment https://www.classiczcars.com/topic/15021-fuel-pump-relays/#findComment-115494 Share on other sites More sharing options...
sblake01 Posted March 7, 2005 Share #4 Posted March 7, 2005 In your profile I see you have a 76. The fuel pump relays are located in the box next to the front passenger side strut tower. Link to comment https://www.classiczcars.com/topic/15021-fuel-pump-relays/#findComment-115511 Share on other sites More sharing options...
