v_balge Posted February 23, 2005 Share #1 Posted February 23, 2005 I'm getting ready to replace the valve stem seals on my 280z with the head still on the car method. The descriptions I've read say to turn the engine over by hand. Whats the best way to do this? Is it safe to use the cam shaft sprocket?Vince Link to comment https://www.classiczcars.com/topic/15089-turning-engine-over-by-hand/ Share on other sites More sharing options...
MikeW Posted February 23, 2005 Share #2 Posted February 23, 2005 I'm getting ready to replace the valve stem seals on my 280z with the head still on the car method. The descriptions I've read say to turn the engine over by hand. Whats the best way to do this? Is it safe to use the cam shaft sprocket?Normally you'd just use a longer breaker bar with a socket on the crankshaft pulley bolt. You can do this without even taking the valve cover off. I'd do that instead of trying the camshaft idea. I think it's a 27mm bolt. Link to comment https://www.classiczcars.com/topic/15089-turning-engine-over-by-hand/#findComment-113900 Share on other sites More sharing options...
Bambikiller240 Posted February 23, 2005 Share #3 Posted February 23, 2005 Yep, 27mm socket is the one for the crankshaft. Rotate in direction of normal engine operation. Link to comment https://www.classiczcars.com/topic/15089-turning-engine-over-by-hand/#findComment-113906 Share on other sites More sharing options...
v_balge Posted February 23, 2005 Author Share #4 Posted February 23, 2005 Thanks!!!!!! Link to comment https://www.classiczcars.com/topic/15089-turning-engine-over-by-hand/#findComment-113907 Share on other sites More sharing options...
