I was given a 1979 ZX that is not running.. I tested the fuel pump and it was shorted out. I got another one, replaced the old one and now I have no voltage to the fuel pump. The fusible link was blown, so I replaced it. But still I have no voltage to the pump. I haver tried to trace the lines to it but can not see where the break is or the problem with it.
I would appreciate any help anyone can offer.. I am stumped and am not sure where to go next.
Thanks
https://www.classiczcars.com/forums/topic/15210-no-voltage-at-fuel-pump/
Does the engine turn over when you turn the key? I ask because I had a similer problem with my '76 Z and it was frustrating trying to troubleshoot. It could be a wire coming off of the battery, or it could be a fusible link (if you're ZX even has them, I'm not quite sure). Just a mere connecton problem gave me hell for a while.
