Control Valve and EGR Control Valve wiring
Hi all
Have an early 260z and I'm rebuilding a stock intake manifold for it. Hit a snag when it come to the wire leads from the Throttle Opener Control Valve (BY wire not seen in picture) and EGR Control Valve (GY wire seen in picture - yellow arrows) were do they connect to and and what kind of connector is on the raditator side if any. I have a partial wire lead but the radiator side has be chopped.
Pictures would be a big help. :ermm:
Thanks
Jim
1974 260Z - RLS30-020697 (01/74)
Note: Picture is not of my 260 just for illustration purposes. Picture file to big Will upload as soon as I can.
Many of the 2-pole connectors on the engine are just injector connectors.
By control valve, do you mean the Aux Air Valve? It lets a little extra air into the intake so your engine idles higher while a little heater inside makes a bimetal valve close off slowly. Mine was dead, so I had to order a new one.
Can you give any specifics or some more details about the EGR valve? There are several components involved in controlling the EGR
thx
  • Who's Online   2 Members, 0 Anonymous, 1,536 Guests (See full list)
