Tomohawk,
If you have 'implemented' any of your ideas, and probably just because you're always coming up with some interesting idea to 'improve' your car, maybe you should remove the (stock) part out of your avatar description.
It's pretty obvious you are not satisfied with your 280 being stock, but putting the (stock) in the description implies you are satisified and proud it's stock.
I don't think that's the case at all viewing all your previous posts.
Implement some of your ideas, or explain what you've done, and quit wasting everyones time implying you don't have time and someone else should do them and share their findings with the group.
Just my .02 dollars (is this the correct way to say it?)
Sincerely,
