i have a 79 280zx 5 speed L28E :( i want to put the turbo stuff on it basically do a swap for now. i will run low boost levels i just want that extra kick in the pants,LOL. what would yall reccomend me gitting to do this Frankenturbo?? im thinking; injectors, turbo manifold, intercooler, Turbo(duh,lmao). would i also need to look for a particular ECU or PCM?? what years to look for basic direction pointing tips would be nice,LOL. thanks guys for your time.
https://www.classiczcars.com/topic/15436-turbo-my-79-zx/
It's the same engine so it shouldn't matter if it's in a 240z, 280z, or 280zx. As for the turbo swap I've been thinking about doing the same thing on my 77. Both the 280z and 79-80 280zx had low compression stock so adding a turbo to it should be possible without doing damage. If I find any other solid proof from more experienced people I'll let you know but for now I would hold off until you found how much boost you could run. Personaly I would like to make 250-300hp and if I can do that using my current engine and low boost I'll probably do that rather than swap in a whole 280zx turbo engine.
https://www.classiczcars.com/topic/15436-turbo-my-79-zx/#findComment-118624
  • Who's Online   2 Members, 0 Anonymous, 603 Guests (See full list)
