You might consider rebuilding the caliper since your having trouble with them. If the piston has any surface rust they will stick in the bore. Usually causing the brakes to wear uneven. A clear sign is one pad being thinner than it's partner. These brakes are over 30 years old and chances are the piston needs to be cleaned and the O-ring replaced. Never disassemble the two halves of the caliper or it will leak. You might also consider getting some remanufacured calipers. Remember that brake fluid is corrosive it will desolve the paint from any surface it comes in contact with. SO when your done wash every surface with plenty of water.
Good luck
https://www.classiczcars.com/topic/15489-brakes/#findComment-118880
  • Who's Online   2 Members, 0 Anonymous, 1,084 Guests (See full list)
