Hi all,
I have what I am assuming is an aftermarket cruise control mounted to the firewall. About a 4" can with a beaded chain going to the throttle linkage.
Since I have a duplicate in my parts box from the PO's donor parts car, I thought it might have been a dealer installed option or just a popular '70s addon.
As far as I can tell it is no longer connected to the electrical system. The wiring goes thru the firewall and ends in a tangle under the glove box. I plan on ripping it all out since I vaguely remember (yeah, I'm that old) they weren't that great, the controls don't look stock, and I never plan on using cruise anyway.
There are also 2 wires going to the front of the engine to what looks like a sensor mounted to the lower timing cover. It is under the distributor and close to the crank pulley. I assume it is part of the speed control to sense engine rpm.
So...............
Anybody else have this on their cars?
Am I right about the sensor? Is it needed for anything else?
Is there anything else I should be on the lookout for when I disconnect the cruise beyond the expected connections (brake switch, power etc.)?
Thanks again for letting me tap the Z think tank.
Bart
https://www.classiczcars.com/topic/15566-aftermarket-cruise-control/
  • Who's Online   2 Members, 0 Anonymous, 628 Guests (See full list)
