Yep, get all the petrol out as it will gum up if you don't. Clean them well & pop them in an air tight bag with a heap of silica gel to absorb any moisture that tries to get in. I'd remove all the brass jets, lube the threads and put them back but only finger tight.
Maybe there is a product that you can also spray coat them with to stop the aluminium corroding. I'd look that up to see.
