Hey every one.
My goal is to have my car in primer by the end of this summer. Only a little bit left to go!
I really want different rims for my baby when she is ready for paint.
I looked at msa and a feiw other places. Can somebody point me into the correct direction? or give me some info on thease?
http://www.classiczcars.com/photopost/showphoto.php?photo=14761&sort=&page=9&sortby=&sorttime=&sortdir=
I am open for somebodys input on diff wheels im shopping!
https://www.classiczcars.com/topic/15667-chrome-rewinds/
Bill, the Panasports are really nice looking wheels however, if you want to be different, as tons of folks run the Panasports, you may consider something different. Your choices will increase if you incorperate wheel adaptors that change the stock Datsun bolt pattern to the Honda bolt pattern. Most wheels available today are intended for front wheel drive cars (more offset, compensated by the applicable width of the wheel adaptors), so there are by far more wheels to choose from. You can opt for 15", 16", 17" or even 18" wheels. As long as you don't use a wheel wider than 7" or 8" you should be able to have them fit under your Z without issues.....any wider wheel and you will likely need to convert to coilovers to achieve for the additional clearance needed. Just some food for thought Bill.
https://www.classiczcars.com/topic/15667-chrome-rewinds/#findComment-121031
