it is a 70 240z and it is the actual ball joint and steering knuckle. so the old one had to be put back in for now. there is a 70 in the junk yard but if it, the knuckle, is from another car a may put in the correct joint for that steering knuckle.
Later 240Z's had ball joints. steering knuckles & tie-rod ends that had different dimensions than the 1970 versions. As far as I know, the 1970 versions are no longer available. You may need to swap it all out for the later (more robust) versions.
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
