I know its a 240C, but someone may be interested in this ad:
For Sale - 1UZFE 240C project no time to work on it at all with the new bub - its just been sitting there for a number of months now. its engineered to this point and only needs final certification ($250). it doesnt even need a brake test. modified volvo automatic shifter. rack and pinion steering conversion is great and works a treat with only 1.0mm toe at full bump/rebound. has new tie rod ends and unis on the steering shaft too. 100% engineered. tailshaft is complete with new unis, centre carrier and splines and a full balance. gearbox has a tiptronic controller to control the std auto - shifting is via the horn buttons. pod filter and mild steel piping (have a volvo airbox if you prefer) chev 4 core radiator with twin 10in davies craig thermos hooked up to run full time. can be modded to run on a temp switch if need be. fuel system is a pierburg feeding a 1.5L anti-surge tank with a bosch feeding the engine. using std 240C feed and return lines (may want to upgrade). interior is mint original with charcoal sheepskins and charcoal carpets. Engine is modified to run a Delco computer as a sponsorship deal - and the fitting and tuning will be provided free by Alan Gibbs at Injection Perfection, all you need to pay for is a new module ($250) & new O2 sensor ($70). he will also wire up the tiptronic auto at the same time. exhaust isnt done. cant get a quote from locals because i have no time. CARLINE in osborne park, and TIM SLAKO racing have expressed a lot of interest in making some mandrel headers and exhaust. alternator may need new bearings - is a little squeaky. needs serpentine belt radiator hoses throttle cable coolant oil filter all the hard work is done. this was quoted as a $12,000 drive in, tow-out-with-no-computer-deal by 2 perth workshops. all welding by qualified and currently employed boilermakers. looking for $4500 firm - basically i just want back what i have spent or will look at swap with a VERY GOOD CONDITION 1000, 1200 or 1600 sedan - something along the lines of Cals 1000 (minus webers, of course!). pics at www.freewebs.com/pro240c/ thanks for looking.
Car Identification: P230 Cedric
Price: $4000 ono Location: Karrinyup WA
Contact: Aaron Email: pro240c@ozdat.com
Phone: 0423 972 359
https://www.classiczcars.com/topic/15816-v8-240c-on-ozdat/
hey! word gets around fast!
this is my car. there is a very genuine reason for sale - i need the cash to buy a block of land.
as well as that, i literally have no time to work on it now with my 3month old bub to look after - it's almost being "neglected".
i'll take $4000 now just to update - it really has to go.
and yes, i'm very sad. :(
https://www.classiczcars.com/topic/15816-v8-240c-on-ozdat/#findComment-124277
  • Who's Online   0 Members, 0 Anonymous, 1,544 Guests (See full list)
