Don't they care what you do after inspection? Here, you have to have an engineers report done and pass an inspection with the new driveline.
Well, it hasn't passed the initial check up ... I skipped it since the car was
pretty much ... FUBAR. So, I thought we should fix the rust first, before
proceding with the check up.
After the check up/initial registration, I'm pretty free to do whatever I want.
Discbrakes for instance. 10+ point rollcage. Fuel cell. Engine/tranny swap.
There's pretty much no emission regulations on cars older than -76, cars
over 30 years old are also declared exempt from tax. Yay!
Speaking of brakes, I was thinking of something along the lines of this:
...Or I might settle for something less heavy : ) Like this:
Philip,
My hat goes off to you. You are doing an outstanding job. You show true passion for your Z. Keep up the good work and keep those excellent video's coming. They are great!
Here is a little something that will hopefully help you:
(If it's too small let me know I can email you a larger size picture 2200 x 2000)
Thanks alot Ed!
Hopefully there's a new video coming soon since I'm getting some tutoring
on soldering later on today. Looking forward to it. Gonna have some bumps
hammered out as well (I hope).
I actually already have the larger version of the picture you attached. Great
big thanks anyway. It's good to know us Z-nuts help eachother out, cheers! =)
Now, some "progress":
Yesterday I visited a friend, who had a friend (who's good with electronics)
over and they had a look at my taillights. If I tell you that I've ordered 15
red bright LED's for testing - I think you can put two and two together :P
I'll hopefully have custom made curcuitboards for this piece of the puzzle.
Right now I'm just waiting for the LED's in order to do some testing...
There's been some investigation done into this previously.... link
Will you use lead throughout the car? Will you not use a bondo-type substance anywhere? I had a '32 Ford 3-window coupe that we used lead on in 1959. It worked great! They have perfected the 'plastics' so well that no one uses lead anymore. Interesting that this is what your boys are using. Fascinating!
I wanted to learn how to work with lead soldering. Mainly using it now to
smooth out some bumps that can't be hammered or by pushing from behind
by using different instruments. Near the drip rail on the roof for instance.
It's also to perfect the area around the welds and seal them up good.
I'm no expert, so this is pretty rough around the edges, and fiberglass
bondo will be used after the car is either painted with epoxy primer or
POR15. Currently looks like the epoxy is the winning choice since it's
what the sand blasing company uses. The car is going back for a light
blasing of the welds, etc. I'll use POR on the floors and other places
where extra rust protection is needed.
When the car is primed/rust protected - caulk will be added to all the
seams. Inside and out. I got some goodies from a company called Auto-
experten that will be used for this:
I understand your usage of materials. I would have loved to use lead on some of my body areas. It seals up and does not rust. Oh well, I will just have to trust the modern plastics. I think you are doing the correct thing in using all of the materials available. It will be a nice car when finished.
  • Who's Online   1 Member, 0 Anonymous, 1,280 Guests (See full list)
