Hello,
I am in the process of assembling the front hubs and have a question. With the spacer in place, I can no longer center the rotor on the hub and there is no centering lip on the spacer, is it going to be a problem? There is a very small amount of play before I tighten the bolts. If the rotor is off center just a hair... I did not what this to cause a vibration or something worse. The JSK web site is down so no help there. For those that have done this upgrade, have you run into any problems?
Thanks,
Skip
Early 260Z
https://www.classiczcars.com/topic/15969-jsk-spacer/
