ncz , I recently replaced the passenger side floor pan with a Zedd Findings unit. They are first class and fit quite well , with little fitting. I over lapped my edges about 1 1/2'' and held it in place with self tapping sheetmetal screws so the welder could not waist time having to do any thing but weld the seam and remove the screws and fill them as he went . Be sure to clean the metal well on both sides before assembly . There is a welder here on the site that uses a paint made just for this process that supresses rust in the weld. You might do a search for that info. I used POR both on top and under to seal the bare metal.
