  • 3 weeks later...
I have a unique problem with the upper strut gland nut. The ones currently in the car well at least the front right hand side are circular and not a octagon shape like it should be.
This means I can't get a grip on it with a pipe wrench or the snap on tool above as they are designed for the normal octagon shape nut. One thing I noted about the circular one was that it has two holes directly opposite each other like you could insert something into them and turn it out that way.
I guess my options with my limited tools are to take it to a suspension shop or ask a friend who might have the tool.
The Tokico's I got from someone here in Australia came with the octagon shaped nuts so I'll probably put those on instead it's just getting them off to begin with.
PS: Anyone know where to get 270 + LB springs in Australia to suit a Z?
Help? :nervous:
  • 3 weeks later...
Large Crescent Wrench (Adjustable Spanner) or a Pipe Wrench. Wrap the the piston rod of the strut to protect it if the wrench slips.
There is a "Special Tool" for this job, but it's way more expensive than the two suggestions above.
SPECIAL TOOL # 100000347-00592
I can sell you one for $60.00. :geek:
Way too late. I've finished all that and the springs and shocks have settled in nicely. I'm now mid way through fitting 35mm spacers so I can run silvia rims and have some longer wheel studs I have to cut down.
No sleep for the Zed LOL
  • Who's Online   1 Member, 0 Anonymous, 1,431 Guests (See full list)
