I spent the last 30min searching the forums for the solution
to the little problem I am having and have not really found a
answer.
I put a electric fuel pump in my 71 and used the wiring that
is in the car for a electric fuel pump. I have the fuel pump
connected to the existing wires for a electric fuel pump that
are at the tank sending unit. The - wire that is in the harness
is grounded to the chassis at some point. The + wire goes
to a T plug that was taped to the wire harness behind the
radio with blue tape. At this time there is no battery in the
car and I am running the fuel pump off of a 12V power source
connected to the T connector behind the radio and grounded
to the chassis.
The car has not been running in 6 years so I installed a electric
fuel pump with a filter before it and a filter up front and I am
pumping Kerosene out and back in to the tank to clean it up.
I will leave the fuel pump and filters and use them once I get
the car running.
My questions are
1)Where does the other wire go that is in the T connector?
2)Did the dealer use a relay and where was it?
3)Where was the fuse they used (In Line?)
I want to use as much of the factory wiring as I can in this
conversion.
https://www.classiczcars.com/topic/16013-71-fuel-pump-wiring/
  • Who's Online   0 Members, 0 Anonymous, 687 Guests (See full list)
