My new KONIG 15x7 rims with COOPER COBRA RADIAL G/T 225-50-15.
I had placed an order with MSA $630 shipped but the rims are on backorder and they have a long list of buyers and could give me no ship date. I cancelled the order and ordered them from TYLER ggtyler@yahoo.com $545 shipped. They are silver with polished lip and they look great.....
A few thoughts..... They came without lug nuts so I got them at my tire shop, standard 12x1.25m.
The KONIG supplied center caps will not fit the front dust cover so I had a set of larger caps with the Z center that I had for my 72 240Z and with some grinding they fit...DAMN.
The front tires rubbed on my MSA type 3 air dam so with a little grinding on the rear lip of the air dam that was fixed.
I also notice with the wider tire the steering is much easier.....:love:
LARRY
https://www.classiczcars.com/topic/16040-konig-rewinds/
along the same lines, is anyone interested in a group buy for 16x8s?
http://forums.hybridz.org/showthread.php?t=101587
No price listed yet, but apparently if 30 sets are preordered, konig can make the rewinds in 16x8, which would be very awesome. the 15x7" wheels are 13.3lbs each, which is pretty good, and they look great (for konig, anyway).
Anyone interested in 16x8 wheels like that?
https://www.classiczcars.com/topic/16040-konig-rewinds/#findComment-125782
Well...... It's too late for pics so let me see if I can explain it. I was so DAMN mad at this that I forgot to take pics. The reason that I can't take them now is that I used some liquid weld to make sure they stayed on. I ground on the inside of the cap tabs and then bent the ends out while they were hot so they would catch on the wheel and then put the weld on the outside of the tab to secure the cap with the wheel. I hope this makes sense... :nervous: Just remember the front caps require more grinding then the rear caps do on accont of the tight fit between the front spindle caps and the wheel....
LARRY
https://www.classiczcars.com/topic/16040-konig-rewinds/#findComment-125973
Ugh, so they are permanently stuck on the wheels? I'm looking to avoid doing that, but thanks anyway for the description. Seems that would make replacing tires or having new tires balanced on the wheels a major problem without sacrificing the caps and starting all over again.
https://www.classiczcars.com/topic/16040-konig-rewinds/#findComment-125979
Let me say this ...It's a crap shoot. Do as I outlined and skip the glue and loose a cap and drive around with missing cap/caps and have to reorder new ones or do it the way I explained..... Now you know why I was "Mad As Hell" and I'm not going to use the original ones by hammering on the spindle cap as I have read elsewhere....:finger:
LARRY
https://www.classiczcars.com/topic/16040-konig-rewinds/#findComment-125991
  • Who's Online   2 Members, 0 Anonymous, 1,541 Guests (See full list)
