uhoh7 Posted May 27, 2005 Share #1 Posted May 27, 2005 I'm getting ready to swap enignes in my 73. I'm trying to plan so I can do it over a weekend. I will pull the engine and trans, then swap the trans to new motor, replacing clutch and throughout bearing in the process. Then it goes back in. the car is in good shape but has not been apart since new. I hear its a good idea to replace bolts (i am replacing motor and trans mounts). My question, and I have tried to find it in searches, What bolts will I run into and how can i find the dimensions in advance so I can order them? I live in the boonies, so I can't walk down the street and get them. Thanks guys Link to comment https://www.classiczcars.com/topic/16060-replacing-bolts/ Share on other sites More sharing options...
Marty Rogan Posted May 27, 2005 Share #2 Posted May 27, 2005 Your best bet is buy the Club's PArts CD and buy them direct from a Nissan Dealer, or Courtesy Nissan: http://www.courtesynissan.com/en_US/HomePage_1.chtmlAs long as the engine is out, you should also replace the tranny pilot bushing.It's also a good time to get there and scrub out and fix anything in the engine bay that needs attention.Marty Link to comment https://www.classiczcars.com/topic/16060-replacing-bolts/#findComment-125386 Share on other sites More sharing options...
dkd021 Posted May 27, 2005 Share #3 Posted May 27, 2005 Have you tried zcarcreations.com? I bought several bolt kits from them & have been satisfied to date. Link to comment https://www.classiczcars.com/topic/16060-replacing-bolts/#findComment-125392 Share on other sites More sharing options...
Bambikiller240 Posted May 27, 2005 Share #4 Posted May 27, 2005 I can't think of a reason to replace the bolts you'll run into doing an engine swap, unless you find them damaged or rusty beyond belief. Link to comment https://www.classiczcars.com/topic/16060-replacing-bolts/#findComment-125400 Share on other sites More sharing options...
uhoh7 Posted May 28, 2005 Author Share #5 Posted May 28, 2005 Ty guysMarty espcially-- I forgot about the pilot bushing!!!! I have the throwout bearing but not the bushing.I'm tempted to use the old bolts, but have been advised I would be crazy to do so.great help hereuhoh7 Link to comment https://www.classiczcars.com/topic/16060-replacing-bolts/#findComment-125419 Share on other sites More sharing options...
Bambikiller240 Posted May 28, 2005 Share #6 Posted May 28, 2005 If you were advised to do engine swap while naked, and smothered in strawberry jam would you do it? Link to comment https://www.classiczcars.com/topic/16060-replacing-bolts/#findComment-125420 Share on other sites More sharing options...
Ed Posted May 28, 2005 Share #7 Posted May 28, 2005 I agree with Carl, there is no reason you couldn't re-use the old bolts. As long as they aren't rusted or deformed. If any, the only bolts you might want to replace are the flywheel bolts. But I've re-used those many times without any problems. Link to comment https://www.classiczcars.com/topic/16060-replacing-bolts/#findComment-125423 Share on other sites More sharing options...
hls30.com Posted May 28, 2005 Share #8 Posted May 28, 2005 I bought a cheep tap and die set from harbor freight to find bolt sizes with, and to chase the treads-it came with a thread guide that has really been helpful(the tap and die set in far from all inclusive.) Maybe the size and thread info should go in a chart in the archives...If you were advised to do engine swap while naked, and smothered in strawberry jam would you do it?Only in your garage big boy!Some hot female member in Carls' neck of the woods needs to check out his garage, and forget that never kiss and tell crap... Bill Ramsey needs some help with his bolt, and probably a nut or two!! Come on Guys-you know his car(among other things) is rusty... Let's not forget to show our friends across the pond that O2 sensors are not the only things we are fascinated with!That said, I am reusing the hardware that cleans up pretty, and saving the ugly but not rusty ones for mockup use(I am setting up my drive train in a '73 that could use paint, to keep the scarrs off the bodywork I am working so hard on(Ok, I am still stripping the removeable panels-I still don't want more body work to do, or to have to wait to do it.)Will Link to comment https://www.classiczcars.com/topic/16060-replacing-bolts/#findComment-125433 Share on other sites More sharing options...
