Hey guys, i finally got around to installing my Grant wooden steering wheel which i like!, but the problem is, i cant get the damn thing straight! when i drive straight, the wheel is a little to the left. then i stop and correct it, then it is to the right...and there is no space between.
i guess what i should be looking at is another adjustment point? the only two things i can think of is the beginning of the steering collum after the rubber bushing, and closer to the rack, but im scared moving those one notch will move the wheel way to much...
any options guys?
https://www.classiczcars.com/topic/16159-steering-wheel-alignment/
Adjust the left tie rod 1 turn longer, and the right tie rod 1 turn shorter. I'm just making an example, I have no idea (from here) which rod should go longer/shorter or by how much.
If you change each in the correct direction by the same amout it will not change your wheel alignment, only where "neutral" is on your steering wheel.
  • Who's Online   2 Members, 0 Anonymous, 1,530 Guests (See full list)
