Shameless plug? Are you the Warren at All Z-Parts mentioned above?
__________________
Carl Stahlnecker
No Shameless plugs here Carl, you joined the wrong dots.
I will say though that Warren from All Z Parts is good guy to deal with, must be in the name. Now that's a shameless plug
Cheers
WarrenZ
Cheers
WarrenZ
I was just curious. Sorry, My bad.
  • 2 months later...
Do any of you guys known the ohms range of the nissan pressure sender? Or the direction o fthe resistance gradient? Does resistance go up with increased pressure or down with increased pressure?
I've had a similair problem to the original poster, but it is a VDO pressure trans, not a switch. My guage has been showing ~85psi with no oil pressure, then dropping to ~30psi with ~50psi real oil pressure.
I suspected to have this problem, just took a (wrong) guess as to which sender to get?
There are a lot of senders around that are less than half the price of Warren's OEM units, with a wide range of specs, just need to know what the specs are to get the right unit.
PS. good to see some Aussies here.
