I recently bought one from Danny's Datsuns. I'm sure he has many more. I bought some other items as well and when I was cleaning them up, I realized that a carb heat shield wasn't up to my standard. Danny rushed me out another no problem. He was really good to deal with AND he stands behind his parts. :)
You may look into a tachometer from a "75 or so. I understand that the "72 tach will not work with the newer distributor. Many threads on the subject I'm sure.
Danny's Datsuns: 541-430-1180, Sutherlin, Oregon
https://www.classiczcars.com/topic/16180-280zx-dizzy/#findComment-126666
I wouldn't just slap one on from a JY, many of those are just worn out. A ZX Dizzy with shaft play is worse than a good points dizzy. Mine was built by Gary Boone, who builds EI dizzys for the roadsters and Z's. Not only is it rebuilt, he also tailors the advance curve.
Info and contact at http://www.nowroc.com/Webpages/Techtips/ElDizzy.htm
It works fine with my stock 72 tach
https://www.classiczcars.com/topic/16180-280zx-dizzy/#findComment-126699
