Site Updates this Weekend ×
i started to replace my qtr windows so i can begin the doors. im kind of... or completely new at dealing with weatherstrips. so far i got the inner qtr seals onto the glass and put the metal frame back on. now i have to put the window back on to the body with the outer qtr seal. here's the question... do i put the outer seal on the window before i put it on the body? or do i put it on the body and then stick the window on? sorry if this is a dumb question but i dont wanna screw anything up. thanks a lot
https://www.classiczcars.com/topic/16249-weatherstrip-for-qtr-window/
The Qtr. Window Seal is glued to the Qtr. Window Frame with the "taller" leg towards the outside THEN it gets compressed when fitted to the body. Additional Sealant is normally NOT required when mounting the window on the body.
Be aware that it is a b!t¢h to compress the gasket AND get the screws started while making sure the gasket doesn't slip off the metal frame. For that reason, use a good high-strength adhesive (3M Weatherstrip Adhesive in Black comes to mind) follow the directions carefully (i.e. clean metal and gasket well, apply one coat to each, allow to dry and then re-apply a SMALL amount for final fitting, tape and let sit for 24 hours), BEFORE you start trying to mount the windows to the car.
2¢
Enrique
