Well here it is, the end was not the bent part so it doesnt require any grinding down to fit etc. Its still slightly pissed, but probably only .5/mm along its length. Its now off and free etc so you can see it properly, if you can measure yours we will be able to see if its the same length as the 2+2 and go from there.
The one in the photo is about 14.3cms long including the head of it.
I actually have that one as well, it is considerably shorter then the one I am using. I took me a good part of Monday afternoon to work out what was going on before I realised I must have parts from two different model cars. The one I require is closer to 20cm.
I will take some pictures of everything I have tonight, it may clear things up for people in the future as well because it sure had me confused for a while.
  • Who's Online   1 Member, 0 Anonymous, 1,503 Guests (See full list)
