Site Updates this Weekend ×
Are OEM factory fenders still available?
I'm glad I got mine six months ago.
I just called my local Nissan dealer & he said they were on backorder but they will be available again in the future. I told him that another dealer said that they are NLA & I was told that was incorrect, & he reiterated to me that they will be available in the future. I certainly can't back that up, I'm just relaying the message. Whatever you do though, don't waste your time &/or money with the aftermarket ones. I've seen them come close to fitting on one car & way off on another.
Your's sound like an easy fix, aftermarket are not worth the money but then I have also heard that the OEM fenders are now from an aftermarket vendor and are of the same low quality. If all you have are dents and no rust I would fix the originals, you will spend more time straightening "new" ones than you would fixing yours, and they already fit!
  • 3 weeks later...
Mark,
Contact the folowing:
John Harris at Passport Nissan in Marlow Heights , Maryland at 301-423-6930. They can still be had and the price is approximately $230.00 each.
I almost forgot, when you get them be sure to coat the insides with POR-15 or something of that nature to protect against rock chips getting past the fender liner.
The two big errors I found in my aftermarket fender was that the front edge was poorly rolled at the point on the top of the fender where the headlight bucket mounts and the latch? for the access door stuck out about 3/4" longer, so much so that there would not be enough adjustment on the latch to make the door close correctly.
From what I can see in the pic the front edge looks nicely rolled, so I would bet that you did get OEM.
  • Who's Online   1 Member, 0 Anonymous, 1,102 Guests (See full list)
