280zx door lock module location-help!
Hi David,____From the factory service manual section EL page 68 and page 128. The system consists of a switch located in each door, an actuator located in each door, and a timer located under the left side kick panel. It appears that the timer is below the room lamp timer and behind the ECU.
  • Who's Online   0 Members, 0 Anonymous, 1,476 Guests (See full list)
