A two piece rim has a removable center on a static rim width that would allow you to install a different lug pattern center or change the offset of the wheel by changing the offset of the center section that is installed onto that wheel.
A three piece is as described above, allowing you to change the width of the rim as well as the center section.
  • 1 month later...
