door trims off - car useable?
I'm planning to remove my door trims to have them refurbished. Removal will involve undoing the door lever, armrests etc (something I've not done before). Will I be able to leave the car in a driveable state while the trims are away being spruced up? ie, will I still be able to open, close, lock the door and drive the car without the trims?
https://www.classiczcars.com/topic/16407-door-trims-off-car-useable/
It'll look pretty "Mad Max" inside, but yes, you will be able to use the door as normal. Might also be a good opportunity to spray some sort of rust prevention goop in the bottoms of the doors too..
Are you refurbishing them, or getting the done somewhere?
Err, too late for the rust prevention goop I'm afraid! I wil do that after the body resto has been done...
I'm going to take the trims to a local vinyl/auto trimmer/repair place along with some of the interior plastic peices which have also faded. They are able to mix and match new dye/paint, repair cracks and repaint. As my interior is Tan in colour (and I want to keep it original rather than black), I'll need professional help...
