Planning a purchase of a 280Z for a V-8 conversion, but I've heard that the R-180 won't hold up to the V-8, and the R-200 will?
Is there an easy way to tell which cars would have the R-200 differential?
Maybe I could graft on a diff from an AUDI QUATTRO??
ref: JTR v8 conversion book.
As far as the R-200 from the Z cars go, any 280 after 1975 will have the R-200. The late 300ZX's also used an R-200 variation, but these will require quite a bit of work to use in an early Z, they used CV joints instead of U-joints so they won't be a simple bolt in. I would look for one from a 75-about 84 for a direct bolt in.
The R-180 won't hold up to a V-8 conversion for very long, it might work but won't last very long compared to the R-200.
In a side by side comparison an R-200 is considerably larger than the R-180.
Not sure about the Audi, but I do believe some of the Subaru's used an R-200 diff. Not sure which ones but I'm quite sure that the Torson unit I have for an R-200 was made for a Subaru application.
From what I've heard and read, some of the Subaru's had an R-200 with a Torson. Never have figured out which year or model it may have came in though. I bought an R-200 a while back with a Torson unit in it and was told the Torson was for a Subaru, that's about all I know. Never have taken the time to do any research on it.
There were no limited slips offered from the factory in a Z until about 87 if I remember right.
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
