Site Updates this Weekend ×
Well i started distruction on the Z today. Taking the front right hand fender off so i could start cutting out the old frame rail.
After i got it pulled apart i discovered alot of crash damage.
The rail that the upper shock gose into. Just behind the tower is bent pretty badly. Somebody made a atempt at fixing it. It was cut and welded but the weld is cracking badly.
This isnt a teribly bad thing im cutting the whole section out due to rust anyways. But it scares me. I hope the main part of the frame aint warped or something. Evan with the old sterring parts i changed it still drove straight. And hasnt warn the tires badly. But I might be in deeper trouble then i thought.
This could explain why the fender and hood didnt exactly lighn up. :mad:
Ill have pics up soon if i can get taken in the am.
https://www.classiczcars.com/topic/16516-crash-damage/
Behind the suspension assembly there is a plate that tends to rust out on the Z's it's at the bottom where the chassis is. If that's what your talking about then it's a normal problem in Z's. Pictures would be a good way for us to assess the damage and provide opinion. It could be one of the reasons for the panels not lining up correctly but sometimes it's more the way the panels are put on that causes bad alignment.(provided it's not too badly damaged).
Anyway as Will says don't let it put you off we've all had a car with some form of hidden gremlin I think.
https://www.classiczcars.com/topic/16516-crash-damage/#findComment-130170
  • Who's Online   2 Members, 0 Anonymous, 953 Guests (See full list)
