Site going down soon for upgrades ×
Hello Everyone,
Well, I finally, after much research on this site, decided the exhaust system I will be running on my 280Z.
The set-up:
2.25" exhaust tubing
18" Summit glasspack as a resonator
dynomax utra flo oval mufflerhttp://www.dynomax.com/ultrafloweld.stm
stock manifold
(my engine is stock BTW)
I chose this system because I want my car to be :devious: loud :devious: but not send my neighbors scrambling for their shotguns when I go to work in the morning, or cause my car to sound like a rice rocket.
My question is this; will this set-up provide enough backpressure for a stock engine??? The reason I ask this is because while the dynomax I will be using is an oval style muffler its in reality a fancy looking glasspack (so far as I can tell, check out the link to see what I mean) and I dont want to lose a lot of midrange torque from this system.
SEAN240Z are you out there??? I think you have a very similar system.
BTW any opinions on this system in general are also welcome (volume, tone resonance, etc.)
Thanks!!!!! :classic:
Derek
https://www.classiczcars.com/topic/16559-too-little-backpressure/
Too LITTLE back pressure?
Can you have too little? Oh, I suppose that if you have F.I. you have to have enought pressure to make the O2 sensor work or the car will run rich won't it?
But I would think that the converter will take care of that. ;-)
Otherwise, so long as your exaust system is long enought to keep it from drawing cold air into the head when you shut it off, why would you need back pressure?
Derek
Derek , you should be spot on. You should have great low in torque , at least what these little engines can provide. If you were after only top end performance then I would say go for Headers and 2 1/2'' . I have consulted a few people I know ,that are in the business of building race and performance Z engines and this is the setup you have that is recommended. Bigger isn't always better . ROFL Gary
These are $70 from Summit Racing. Not cheap I know but I researched these mufflers on both this site and the L6 forums on the HybridZ site and everyone that had them seemed to like them a lot, unlike the dynomax super turbo and the flowmaster 40 series which both seem to get mixed reviews.
