There is an alternative to a full fledged rotisserie-it consists of two curverd frames that bolt on the heel hubs with lug nuts and allows the car to be rolled on its side-not useful in a garage unless you have space to roll it over, and not usefull if you plan to remove the suspension-but could be all you need for rust repair-if the suspension mounts are not part of the rust issue.
Will
Look what I've found when searching UK pages:
http://www.cjautos.org.uk/phdi/p1.nsf/supppages/cjautos?opendocument&part=5
Nice, huh?
Les
WOW! Now that's impressive! You don't have to jack the car up repeatedly using cinder blocks to get it high enough to attach it to the rotiss.
