Site going down soon for upgrades ×
I now have the car running and it sounds good. All vacuum hoses replaced, new NGK plugs, new valve cover gasket. I noticed that coolant is seeping from the block at the cylinder head (where they meet) near the #6 cylinder (near firewall) on the passenger side. Does this sound like a blown gasket or is this a sign of a cracked block or head? When I changed the plugs I noticed that this cylinder's plug was the cleanest of the bunch (no carbon). The car is not overheating. Any guidance is appreciated
https://www.classiczcars.com/topic/16604-cracked-block-or-bad-gasket/
The only way to truly find out is to remove the cylinder head, which is probably what you need to do anyway, as you don't want the problem to get worse.
Here are some things to look for:
Signs of water/coolant in the oil
White, billowy smoke emitting from the exhaust
Moisture in the PCV valve hose
These were a few of the signs when the cylinder head on my '73 developed a problem. The engine in my car had coolant leaking into a few cylinders. I ended up having the engine completely rebuilt.
Hope this helps!
