daveinc Posted July 19, 2005 Share #1 Posted July 19, 2005 There are a lot of little electrical issues on this car, however the one that is dangerous is my headlights only work on high beam. They go dark when I toggle the steering switch to low beam. I can noddle with, and figure out most mechanical things, but electrics are the hardest for me. I have done everything I know how to trace the problem but it has me stumped. I am hoping this is some silly little common Z thing that will embarrass me, but is easily fixed :-). (And yes I checked the fuses.) Thanks in advance, David 1978 280Z, 5 speed, factory air (not working either) Link to comment https://www.classiczcars.com/topic/16626-help-with-headlights/ Share on other sites More sharing options...
wal280z Posted July 19, 2005 Share #2 Posted July 19, 2005 There are a lot of little electrical issues on this car, however the one that is dangerous is my headlights only work on high beam. They go dark when I toggle the steering switch to low beam. I can noddle with, and figure out most mechanical things, but electrics are the hardest for me. I have done everything I know how to trace the problem but it has me stumped. I am hoping this is some silly little common Z thing that will embarrass me, but is easily fixedDavid-My '77 has the same problem. I traced it out, disconnecting connectors, checking continuity, etc, and plugged them back in and whala! they worked. Mine is caused from a short somewhere in the harness between the firewall and the fusible link branch. I wiggle the harness and the low beams will re-illuminate. One of the things on my 'to do list', but I don't drive the car in the rain or at night.Wayne Link to comment https://www.classiczcars.com/topic/16626-help-with-headlights/#findComment-131192 Share on other sites More sharing options...
mlc240z Posted July 19, 2005 Share #3 Posted July 19, 2005 1 stupid thing, are you sure both headlights have a good low beam, not blown? i know it's dumb, but check it first before you chase an electric gremlin.after you verify good low beam filaments, i'd check the switch. there's a good tech tip here to clean switch and swap the two rocker contacts to restore your switch.http://www.classiczcars.com/forums/showthread.php?t=17688hope this helps.bart Link to comment https://www.classiczcars.com/topic/16626-help-with-headlights/#findComment-131194 Share on other sites More sharing options...
TomoHawk Posted July 20, 2005 Share #4 Posted July 20, 2005 After that, check the connector under the steering column. Ifyou know which pins to use, you can jumper it to ground to complete the circuit, which is basically what the light switch & dimmer switch do. YOU can test both low and high beams separately that way.If it's not that, it must be something really strange.thx Link to comment https://www.classiczcars.com/topic/16626-help-with-headlights/#findComment-131209 Share on other sites More sharing options...
daveinc Posted July 20, 2005 Author Share #5 Posted July 20, 2005 Thanks Wal280Z, mic240Z, & Tomohawk! Link to comment https://www.classiczcars.com/topic/16626-help-with-headlights/#findComment-131297 Share on other sites More sharing options...
sblake01 Posted July 21, 2005 Share #6 Posted July 21, 2005 When I first got my 78 it also had that problem. Luckily I was able to get another assembly from a parts car at my friends shop and it's been fine ever since. But one day, out of curiousity, I took the old one apart, cleaned it up, lubed it here and there (dielectric grease) and plugged it back in and now it works fine. Link to comment https://www.classiczcars.com/topic/16626-help-with-headlights/#findComment-131315 Share on other sites More sharing options...
