learnerZpermit Posted July 21, 2005 Share #1 Posted July 21, 2005 i recently purchased a 74' 260z with a built L28 swapped in from justazcarguy. problem here is my ignition system. it has an E.I. from mallory, but engine "stumbles" through the RPM band (doesnt matter if its high or low rpm's) the motor is built like i said: silver dllar pistons,P&P n42 head, 6-2-1 header&exhaust,schneider aggressive camshaft,10 or 11:1 comp ( i cant remember), DUAL point mallory dizzy, and last but not least triple 44mm mikkies! so should i "rebuild" the mallory dizzy or swap to a 280zx dizzy ???hmmm... i wonder whats easier? the mallory also has an aftermarket ignition box. and i heard the black box dizzy wont take to the mallory ignition box. help at this point would be nice. :stupid: Link to comment https://www.classiczcars.com/topic/16647-black-box-iggy-or-not/ Share on other sites More sharing options...
learnerZpermit Posted July 21, 2005 Author Share #2 Posted July 21, 2005 new guy on the block needs a lil' help from you gurus out there show me the way of the z car jedi. Link to comment https://www.classiczcars.com/topic/16647-black-box-iggy-or-not/#findComment-131474 Share on other sites More sharing options...
EScanlon Posted July 22, 2005 Share #3 Posted July 22, 2005 It's going to be difficult to diagnose over the internet. You'd be better off contacting Phred (member here) he's on the other side of Portland from JustaZcarguy, and he might be able to offer help. Otherwise ask Brian where he used to take it to get tuned up or invite him over for a beer and pizza to help you tune it.2¢Enrique Link to comment https://www.classiczcars.com/topic/16647-black-box-iggy-or-not/#findComment-131503 Share on other sites More sharing options...
beandip Posted July 22, 2005 Share #4 Posted July 22, 2005 Welcome to the club. Phred rebuilt that head and did a valve job on it not long ago. With the ZX ignition you wont need the black box that you are using now. The ZX ignition has a module on the side of the dist that is all that is needed. You will need a ignition coil that is for a electronic ignition. If the wireing hasn't been cobb up it is a easy mod and will worth the trouble. Find a '79-80 ZX ignition with a 12 - 80 module and a you are good to go. Gary Link to comment https://www.classiczcars.com/topic/16647-black-box-iggy-or-not/#findComment-131510 Share on other sites More sharing options...
learnerZpermit Posted July 22, 2005 Author Share #5 Posted July 22, 2005 thank you all. i think im going to like being part of this "web-clan" you guys are so much more helpful than those ricers ive been associating with. autozone said they'd get me a zx dizzy complete for 110$ ? sound good? its rebuilt so i wont have to play with that whole "ball bearings are loose" ordeal. oh yeah, does it have to be a 79-80 dizzy? or can it be turbo? thank you all again for your generous support of OPB...oh wait, thats on later tonight..... Link to comment https://www.classiczcars.com/topic/16647-black-box-iggy-or-not/#findComment-131573 Share on other sites More sharing options...
