TomoHawk Posted July 22, 2005 Share #1 Posted July 22, 2005 While you're at it cleaning & polishing everything under the hood, what about the alternator? It starts out as a rough-cast shell, but what would it look like with some sanding? You probably wouldn't have to polish it to mirrorness, but a smooth sanded shell ( 600 grit, then steel wool) might look nicer.Would it be difficultto extract the alternator to sand it?thoughts?thx Link to comment https://www.classiczcars.com/topic/16654-sanding-polishing-alternator/ Share on other sites More sharing options...
LanceM Posted July 22, 2005 Share #2 Posted July 22, 2005 My thought would be that it would have to be completely disassembled, which would turn it into a lot more work. You wouldn't want any of the residue from the sanding to get in the works! Link to comment https://www.classiczcars.com/topic/16654-sanding-polishing-alternator/#findComment-131533 Share on other sites More sharing options...
george71z Posted July 22, 2005 Share #3 Posted July 22, 2005 I dis-assembled mine and took the housings to a professional polisher. It can be done at home, if you have the proper materials and tools. LanceM is absolutely right. You don't want any debris getting into the works. Link to comment https://www.classiczcars.com/topic/16654-sanding-polishing-alternator/#findComment-131600 Share on other sites More sharing options...
billcapp Posted July 23, 2005 Share #4 Posted July 23, 2005 :beard: Taking the alternator out is a piece of cake. After mine was rebuilt ($35.00) I just used polishing rouge and a drill with a buffing wheel being careful not to aim it to the inside. It came out like chrome. Don't even sand it with any grit unless it's totally disassembled and cleaned thoroughly. It really doesn't need sand paper anyway. Link to comment https://www.classiczcars.com/topic/16654-sanding-polishing-alternator/#findComment-131629 Share on other sites More sharing options...
