Just looking for a little help here with my '75 280Z. I was coming home yesterday and on the last turn before my house, I pressed the brake. My petal starts going down slowly but down further than it has before and makes an audible hiss when pressed. I checked the fluid and both fluid conisters on the master cylinder were half full. I topped off and (I know silly but had no choice) drove to work this morning. It stops. Kinda. But takes me 4 times the distance to stop and makes a hiss whenever pressed.
Master cylinder?
Master Vac?
Line?
:( Help.:(
https://www.classiczcars.com/topic/1675-brake-hiss-help-please/
Sounds like you have a leak in the vacuum assist part of the system. Doesn't really sound like it's the master cylinder. Check the the hose running from the intake manifold to the brake booster for leaks. If you don't find any there, then it's more than likely inside the booster (the big round black thing on the firewall). I've heard those can be rebuilt but it'd be easier to just get another one and swap it.
Since you can hear it more on the inside than under the hood, I would suspect the master-vac. It may be leaking past the plunger from the brake pedal assembly and through the firewall.
Anothe thing to check is the vacuum line check valve in the middle of the line to the master-vac.
