Did it run before you changed plugs, dist cap etc? If so check the lead wire that connects to the side of the distributor. It is possible that it either slipped off the spade connector or the connector broke inside the small cover on the end of the wire. I have had that happen. To look at the wire it looks good but you may have to slide the protector back to inspect the wire itself. If that all checks out start following the wire back from the distributor to coil to ignition.
I hope this helps. Good luck
Bob
