Checking Headlight/Wiper Switch
Dashboard and tailights/parking quit working. I took the shroud off the column to check out the light/wiper control. On top there are 4 soldered wires. 3 show hot when tested. How can I confirm the control is the culprit for tail and dash lights not working?
Thanks
https://www.classiczcars.com/topic/16779-checking-headlightwiper-switch/
Go to this page http://www.geocities.com/zgarage2001/z.html and look at the "Z problems". The fusebox is a common site for corrosion. I had one fuse box melt down on me.
My experience was this: I would notice the lights being out. I checked the fuse visually, and it looked fine. I pulled it and checked continuity which failed. I replaced the fuse a couple of more times. One time while the lights were still working, I lifted the cover to see the fuse glowing orange, not the best thing to see in your fusebox. Eventually, the fuse heated up enough to melt the plastic. I replaced the fusebox and haven't had a problem since.
If you want to get fancy, you can get an updated fuse box from MSA for $200. It looks sweet.
  • Who's Online   1 Member, 0 Anonymous, 819 Guests (See full list)
