richard1 Posted August 11, 2005 Share #1 Posted August 11, 2005 I recently installed an electric fuel pump on my 72 z to cure the vapor lock problem. I found the wires taped as described at the back of the car. I also found the "L" connectors taped on the driver's side of the console.The problem is the pump works only when the light switch is on. Link to comment https://www.classiczcars.com/topic/16859-electric-fuel-pump-for-a-72-z/ Share on other sites More sharing options...
