Site going down soon for upgrades ×
Well I finally got the top half of the engine apart and here is what I have found, (so far). Well first of all I broke of one of the head bolts eeeek :rolleyes: . Then I found that the #5 injector tip was cracked. The exhaust manifold was cracked right down the middle, the exhaust stud was broken off (not by me). And I also took the intake in to have it bored out for the new throttle body which is going to cost 200.00. And I always wondered why my car ran like s--t, now I know. Well tomorrow is half off at pick and pull so I will be heading down there to get an exhaust manifold and a head bolt and whatever else I need for the 5 speed swap.
My question is what type or year Z injectors will work on my 78. Thanks in advance
https://www.classiczcars.com/topic/16888-engine-coming-apart-problems/
for my 280 i went to a pick n pull for my fuel injector and i ganked one off a 81 z and its working fine. I THINK they are compatible from 1983 and below however i could be wrong. Take the # 5 injector with u and just match it up with something there. Hope this helps!
I found some head bolts after I wrote that question at courtesy nissan (expensive but good) http://www.courtesyparts.com/index.html
I was able to get the head bolt out too, it had enough bolt left on it to grab it with a pipe wrench (gotta love em). I went ahead and ordered me a new fuel rail also new fuel injector gaskets :classic: . I went to pick and pull and got a fuel injector, the fuel injector cooler/blower dont know how good they work but it was half off and got a 240sx throttle body boot and the pedal assembly which doesnt work and another 240sx throttle body, I got it all for 61.00
I have another question, how do you know the difference between a 2+2 and a standard 280z. I am still looking for a flywheel for my Z, that is the only thing that I need for my 5 speed swap and I need a standard one. If anyone happens to have extra one, please let me know. Thanks, Shane
