Hey ya'll i just bought a 78 280z with a 6 cyl. overhead cam. i was able to drive it home but when i got it there it won't start. i have no idea why all of a sudden. i dumped the old fuel and put about 4 gallon in the tank but still no start any ideas??? maybe possible fuel pump? its bugging me really bad (anybody know how big of gas tank would be in that)
https://www.classiczcars.com/topic/16969-car-wont-start/
I unhooked the filters and changed them but no diffrence i just got done taking off the fuel pump and i hooked it up to a trickle charger to see if it would pump and it did but i think it might be in the wiring because when i took it off i checked if it was pumping gas and it wasent i couldnt hear if the pump was running over the engine turning so i'll put the pump back on and see if that does the trick how would i go about checking timing? i have also thought about that route. thanks!!
https://www.classiczcars.com/topic/16969-car-wont-start/#findComment-134910
It was running untill you parked it . Why would you suspect timing all of a sudden ? How was the engine running prior to this ? Was it running smooth ? Missing , running rough , pinging , knocking , what ? Was the car setting for a long time before you bought it? How did you dump the old fuel ? Did you pump it out with the fuel pump that supplies the injectors ? What did you see in the fuel you dumped , rust , dirt , water , what ?? You are not giving us much to go on . I could tell you to replace the ignition , all the injecters , and all the censers , new filters , and spark plugs. And the car may still not run . Come up with more info and someone here will be of help. gary
https://www.classiczcars.com/topic/16969-car-wont-start/#findComment-134924
If you put 4 gal in then it has enough to start. Try fuel filter, fuel pump.
Maybe its your injectors. Im not to great with fuel injection.
I would look at your timeing as well.
This advice needs to be tempered with the fact that that IS what Bill did. His car is now a garage-queen. ROFL
So as Beandip says, before you go removing the engine, changing out the cam, balancing the spark-plugs or some other esoteric 'only happens once in your lifetime' type of repair; remember the car WAS running recently. If nothing was experienced when it STOPPED running (loud bang, sudden stall, engine died suddenly, etc.) then it should NOT require a major re-build .... UNLESS ... your engine blew up (literally).
So look at the simple stuff: clogged fuel line, battery lost charge (or not enough), but check the BASICS first.
FWIW
Enrique
https://www.classiczcars.com/topic/16969-car-wont-start/#findComment-134927
Bill:
I thought I remembered your saying it was parked for repairs. Ok, my bad....LOL
Enrique
Maybe after hearing some of Bill's stories about the car, it should be parked. :ermm: But seriously, check you ignition relay and if it's okay check the fuel pump relays since any of the three can stop the fuel pump from working. You could have just checked the current at the fuel pump rather than removing it. You should follow the correct troubleshooting procedure rather than just throwing parts at the problem. Could get expensive. There is a troubleshooting checklist in the FSM.
https://www.classiczcars.com/topic/16969-car-wont-start/#findComment-134958
well i checked and replaced fuel filters and some bad fuel line i dont think its getting gas because i put some gas in a cyl. and it fires but wont stay running. nothing happened unnormally when it stopped running. all i did was shut it off and tried to start it after about 1 hour i dumped the gas by taking out the drain plug in the gas tank. it didnt look dirty just really old and varnishy. i checked the fuel pump and it dosent pump very good so im looking at replacing it with just a in-line plastic electric fuel pump. unless you have any better ideas. how do you clean the injectors? i can clean a carb in about 20 mins but injectors im stumped with. hey beandip i work at a local marina so just remmber im not totally dumb about troubleshooting engines but this early of injectors have me wondering
https://www.classiczcars.com/topic/16969-car-wont-start/#findComment-134960
I don't think Gary (or I) were trying to incinuate that you were dumb. It's just that I knew quite a bit about engines when I got my Z with EFI. Hell, I've owned 45 cars and a few motorcycles in my lifetime. But the Z is a different story. You really have to get to know the system and I have been working towards that for the last seven years! Prior knowledge is definately a plus, but this system is somewhat unique with its relays, swithches, resistors, etc.
https://www.classiczcars.com/topic/16969-car-wont-start/#findComment-134962
