hoping for some help
i have fitted the 2.8 fuel injected 280zx motor
n54 with p90 head flat top pistons and mild cam
into my 71 240z it has an aftermarket computer
the problem i am having is at 4500 rpm i loss voltage
down to 10.5-11 but only over that rpms
noticed when it was on the dyno
one person has advised a surge tank and lift pump
and a few people advise a upgraded alternator
the auto electrician thought that it was charging correctly and losing it after 4500 rpm it is stilling running the 240z alternater 40amps
rob
https://www.classiczcars.com/topic/16985-voltage-drop-at-4500-rpm/
********Wild Speculation Alert************
I have no idea of the duty cycle of the fuel injection system for the Z car. However, could this be a case of the injectors firing so often combined with the current draw of the ignition system? If you didn't upgrade the alternator with the engine, it could be the case.
Also, what is the normal voltage at the battery at idle? Your voltage regulator might not be adjusted properly.
  • Who's Online   2 Members, 0 Anonymous, 1,435 Guests (See full list)
