Here's an idear
Take a 2 litre coke bottle and cut it in half.
Put a rubber diaphram (air tight) over the cut end.
Aim neck carefully at a candle and tap it with a few fingers,
acording to the web site at
http://www.cs.wits.ac.za/~jon/science/experiments/
you can put out a candle at upto 2m because it generates a vortex
this web site has sum good things to try
"put 3 drops of NACO4 with ....... and Run"
So im thinking ........got piles of junk around
Im so lazy ........slack .....got no money.....and the rest.....
So if we put a speaker in place of the diaphram.
http://images.myphotoalbum.com/s/sm/smo/smok/smoki/smokingwheels/albums/MyEngine/Candle_snuffer1.thumb.jpg
hmmm.....more power to inject into my engine
http://images.myphotoalbum.com/s/sm/smo/smok/smoki/smokingwheels/albums/MyEngine/turbo_1.thumb.jpg
hmmm what would i drive it with, AC/DC, Metallica, sum heavy metal song
with lots of bass boost maybe
hmmm my soundblaster 5.1 se has +18 db of boost in the parametric EQ
Record it at that level if you can by usings another pc
Then playback the recording hence adding another +18 db of bass.
It realy makes the subbies move, doors and windows rattle.
I thought i would give you all one of my idears
Think outside the box
It could just be a certain waveform needed
I am build a test unit with whatever is within my buget
and play music to my engine, while logging
RPM Increase/Per Cyclinder@WOT@45degrees
sounds complex my
1st gear runs at about 15 rpm/cyc
2nd gear runs at about 4.5 rpm/cyc
3rd gear runs but is self incrimaning
4th same see above
5th same see above
I will host the pics at my free photo site
sounds i would have to send out by email
But you would have to be on my list to allow you to access to it.
If you dont think thats fair please let me know
how many km/h you shaved of your 1/4 mile time.
0 to 100 km/h eg traffic lights to sum speed limit sign or post
0 to 60 km/h I wouldnt want you to get booked!
be carefull!
oh make sure they dont Resurvey the signpost
had this done to me a few years ago
number of speakers
power levels
how much of a breaze on your face and at what distace
I could say hair but my mate doesnt have any
output tube size etc
input tube size etc
recordings of input and output wave files (recording with you highest resolution) mp3 ok too
buy $1.00 headphones and use them as mic's
think of a name to call it we could all vote on it with one of those polls here
go to http://www.turbofast.com.au/freesoftware.html and Turbocalc its fun to play with numbers until the trial runs out, im not reinstalling windows for at least another 3 months
So if it doesnt work i wont give up my day job Cause i dont have one
I still have to fit a 500 cfm holley and 4 fuel pumps into my wagon yet
Have Fun
https://www.classiczcars.com/topic/17083-small-turbo-cheap-diy/
good thinking outside of the box, but one small problem - in order for something like that to boost performance of an engine, it needs to provide constant (or at least monodirectional) pressure. with the speaker idea, you would alternate between blowing and sucking, which is definitely a good thing, but not for the perofrmance of a motor ;)
Add some one way valves one on the engine air intake side and one on a cold air intake side. and if that does not work them the hole thing could be modified to administer the other type of smoke that SavannahZ refered too.
